Locking Help
Old Jan 20, 2008 | 03:01 PM
Jim41's Avatar
Default Locking Help
I have an 08 Accord EX. When is push the lock on the fob the first time, the doors lock. When I push it the second time, the horn sounds. Is there away to program for a beep or a lights flash rather then the sound of the horn? I have read through manual and have not been able to find anything on that paticular issue? Thanks
Old Jan 21, 2008 | 09:16 AM
catbert430's Avatar
Default RE: Locking Help
I don't think there's anything you can do to change it.
One push locks the doors and sets the alarm so the easiest way to avoid having to hear the horn is to just push the lock button once instead of twice.
Old Jan 21, 2008 | 11:22 AM
smaglik's Avatar
i thought you could disable that honking. you call your SA?
Old Jan 21, 2008 | 12:29 PM
Jim41's Avatar
Havn't called her yet, actually I havn't met her yet. I will probably have to pick up my plates this week, so I will ask then. Thanks for the feedback gang
Old Jan 21, 2008 | 04:25 PM
patpatpat's Avatar
When you clicked it for the first time, it should just flashes w/o horn. Isnt that what you want?
Old Jan 21, 2008 | 04:52 PM
nafango2's Avatar
you could always re-route the horn honk trigger wire coming from the alarm unit to the parking lights instead...
Old Jan 21, 2008 | 06:28 PM
Jim41's Avatar
Yes Pat, that does work just fine. I used to own a TL and then an RDX and both of those would just beep on the second push. Was wondering if I could do that with this one as well
jgw
May 25, 2011 08:41 AM
Fat Ryan
Jun 23, 2009 01:26 PM
andy 95
Aug 14, 2007 11:58 AM
Data7
Jun 8, 2006 05:31 PM
kpearson10
Aug 23, 2005 02:34 PM
