Lost 3rd and 4th gear
Just bought 2001 accord at auction cheap. Drove fine and did for about 100 miles. Stopped at some construction yesterday and upon moving again it won't shift into 3 or 4 gear. No noises, no warning, just won't shift now. I did fluid changes immediately when I got the car. Tranny fluid was old, almost black, but was clean with no contaminated. Replaced with MaxLife synthetic. Worked good for probably 80+Miles until yesterday.
Not sure this will help much, but MaxLife synthetic is the wrong fluid for your transmission. The only ATF you should use is Honda DW-1 or fluids certified to be DW-1 compatible. The thing is, regardless of how superior (or not) the base oil is, synthetic or otherwise, unless the coefficient of friction is correct, the clutches will not engage properly.
At this point you can try to swap out the MaxLife by doing three consecutive drain and refills of the transmission (doing a few miles of driving in between each change) with DW-1, but I'm not optimistic.
MaxLife claims DW-1 and ATF Z1. Or, at least this version does:
https://sharena21.springcm.com/Publi...51-fe75-e711-9
c10-ac162d889bd3/3fa3136a-09bd-e711-9c12-ac162d889bd1
That said, it could certainly, IMHO, be the non-Honda fluid.
How about a power flush at the dealer?
Roy
Roy
Roy
Roy
I've also heard that Honda automatics don't like to be "power-flushed". Having said that, when a Honda dealer says "flush" the AT, I'm pretty sure what that means to a dealer is the 3x drain & fill.
Toecutter quotes me as if I'm an AT guru. Really not, I just remember threads about it on this board...
OP, you'd have to check for any codes. I only say that, as if there's a problem, it should kick up a code. I didn't see you mentioning any codes present, or if you checked for any.
Are you sure it is the Check Engine Light blinking? What you are describing sounds more like the Maintenance Required light.
