Lost 3rd and 4th gear
Old Mar 16, 2018 | 12:02 PM
freaknumber3's Avatar
It is the orange check engine light, right next to the maintenance light
Old Mar 16, 2018 | 12:35 PM
shipo's Avatar
If that's the case then any decent code reader should be able to pull the codes (and there will be codes).
Old Mar 16, 2018 | 04:05 PM
Code reader shows no codes current or pending. Starting to suspect the PCM. my experiences in the past have been when electrical makes you pull your hair out and nothing makes sense it is the computer.....lol
Old Mar 19, 2018 | 07:21 AM
Electrical problems that make no sense are maybe more likely from bad grounds. (But bad PCMs aren't unheard of either.)
Also, there's about 4 different data protocols for OBD-2 and some of the inexpensive code readers can't read all of them.
Still, the behavior of the lamp to flash for several seconds then stay off is what the service reminder lamp should do. The actual check-engine light should stay on to indicate a fault.
88accorddx
Mar 13, 2013 08:34 PM
gregg0ry
Oct 20, 2009 05:33 AM
Mrheat
Dec 29, 2007 01:40 PM
localcenfla
Sep 19, 2006 03:11 PM
92Inspire
Aug 29, 2006 04:08 PM
