D4 flash... stuck in 4th gear?
Old Sep 16, 2006 | 05:29 PM
localcenfla
Default D4 flash... stuck in 4th gear?
last night my 96 accord (auto trans) seemed to be stuck in 4th. i was running at 55mph for about 30min, stopped for a toll booth when i noticed the D4 light was flashing, the engine was revving high but i had no power. i was able to limp back to the house, shifting (up) manually, checked the fluid. fluid as clean clear red, no burnt smell, and in the middle of that cross-hatched area. this morning it was doing the same thing. but as i was backing out of a parking space i rolled onto a curb with my pass. front wheel. i drove it for about 30 min after that and its shifting like it's supposed to. im lost.... i cant imagine the curb had anything to do with it but...im an air-cooled VW guy, IVE HEARD STRANGER THINGS.
Old Sep 17, 2006 | 03:42 AM
Slusher's Avatar
Default RE: D4 flash... stuck in 4th gear?
I would imagine that it could be 2 things: VSS or TCU. How you go about checking these I'm not sure but if the D4 is flashing its like a check engine light for the tranny. Do a search on here for those two things and you might find someone who had the same issue at some point.
Old Sep 17, 2006 | 01:01 PM
localcenfla
i searched this site and others for anyone having similar symptoms. i came up with what you mentioned, the VSS or the TCU. my speedo is working, that seemed inconsistent with the VSS. now it's shifting good again, every TCU problem i read about the trans stopped shifting completely. im glad that the car seems to be fine now, but i want to solve the problem so it doesnt happen again.
Old Sep 17, 2006 | 02:34 PM
YeuEmMaiMai's Avatar
usually when a trans refuses to shift gears it is because a solenoid has failed, valve bosy is stuck or TCU (electronically controlled trans only). Your problem may return
Old Sep 19, 2006 | 03:11 PM
hondadude's Avatar
if the D4 light was flashing there is a code stored, your car might still have the Blue 2 pin jumper at the top of the passenger side kick panel. you can jumper the connection and get the 'flash' code.
The other way is to have the codes read thru the DLC behind the ashtray.
broncoman1532
Jul 14, 2013 11:24 PM
ziggy!talon
Apr 10, 2008 02:45 PM
Mrheat
Dec 29, 2007 01:40 PM
xfold
Dec 5, 2007 07:22 PM
92Inspire
Aug 29, 2006 04:08 PM
