1994 accord 5 speed stuck in 4th gear
Old Jul 9, 2013 | 10:31 PM
broncoman1532's Avatar
Default 1994 accord 5 speed stuck in 4th gear
Just got this accord and the trans is stuck in 4th gear. The shifter can be moved up and sideways but Its still in 4th. Would this be the linkage Or something on the inside. Really at a losa on this one. Thanks for any input on this. Normally Its just the clutch but thats fine
Old Jul 9, 2013 | 10:38 PM
Take a look where the two cables from the shifter connect to the transmission. Verify the each moves when someone switches gears inside the car.
Old Jul 9, 2013 | 10:43 PM
They dont move. The shifter does really switch gears. It sits in 4th but comes out real easy
Old Jul 10, 2013 | 05:32 PM
Kind of confused on the answer.....next I would pull the part around the shifter and have a look at that end of the cables to be sure everything is attached.
Old Jul 10, 2013 | 05:35 PM
So the shifter moves freely but the transmission does not shift gear, nor do the cables move at the transmission? Sounds like the cables are bad to me.
Old Jul 10, 2013 | 08:44 PM
Im gonna pull the shifter tomorrow Or this weekend hope Its an East fix.
The shifter (while driving) I could move it up like into 3rd amd also side to side like neutral. But the trans itself is still in 4th. I was driving it and was slowing down and it just wouldnt come out If gear.
Old Jul 12, 2013 | 04:56 PM
I was able.to free up the shifter. I took off the cables and put some vice grips on the shifter sticking out of the trans. The trans is still in 4th gear. After putting It all back together It fells like Its goes into 2, 4, and rev. Should I try and change the fluid Or just pull the trans
Old Jul 14, 2013 | 01:29 PM
I pulled the plug to drain the fluid and there was none. Its bone dry. Should I put new fluid in It and see if it will shift right Or just replace It
Old Jul 14, 2013 | 01:55 PM
Worth a try to see if it fixes it. Worst case you are out $40 bucks or whatever ATF costs.
Old Jul 14, 2013 | 11:24 PM
UhOh's Avatar
put 10w-30 dino oil in it. probably $15. give it a whirl.
I've a '92 5spd and use 10W-30 dino or Pennzoil Synchromesh
(can't recall which at the last change)
luck.
trukid21
Sep 25, 2008 09:49 AM
Mrheat
Dec 29, 2007 01:40 PM
xfold
Dec 5, 2007 07:22 PM
localcenfla
Sep 19, 2006 03:11 PM
92Inspire
Aug 29, 2006 04:08 PM
