1994 accord 5 speed stuck in 4th gear
Just got this accord and the trans is stuck in 4th gear. The shifter can be moved up and sideways but Its still in 4th. Would this be the linkage Or something on the inside. Really at a losa on this one. Thanks for any input on this. Normally Its just the clutch but thats fine
Im gonna pull the shifter tomorrow Or this weekend hope Its an East fix.
The shifter (while driving) I could move it up like into 3rd amd also side to side like neutral. But the trans itself is still in 4th. I was driving it and was slowing down and it just wouldnt come out If gear.
I was able.to free up the shifter. I took off the cables and put some vice grips on the shifter sticking out of the trans. The trans is still in 4th gear. After putting It all back together It fells like Its goes into 2, 4, and rev. Should I try and change the fluid Or just pull the trans
I've a '92 5spd and use 10W-30 dino or Pennzoil Synchromesh
(can't recall which at the last change)
luck.
