Lots of Ps
Old Jun 20, 2014 | 04:33 PM
TexomaAccord's Avatar
Default Lots of Ps
p0303
p0305
p1300
p1399 pd
Oy vey... engine idles rough
Misfire, misfire
Flashing check engine.. sometimes it stays on, then flashes like 12 times
Oh the voices in my head and sirens.. go away
Old Jun 20, 2014 | 04:43 PM
1. You can clean the EGR ports to see if it makes a difference, that is easy enough.
2. Have you replace the coil yet, from one of your previous threads?
Old Jun 20, 2014 | 04:46 PM
EGR ports cleaned [x] About a month ago, they were awful and completely full of gunk.
Have not replaced the ignition coil yet -- The tach has been jumpy, but since it didn't cause any problems, I left it alone.
In my shopping cart I have 6 plugs, wire set and an ignition coil..
Think that will cure my problems?
Well, cure my code problems in my car
Old Jun 20, 2014 | 06:15 PM
This is going off-topic; but, I see your avator of a ghost and your profile states you're a paranormal investigator for TV.
Care to share some stories in the off-topic forum section for our entertainment?
Old Jun 20, 2014 | 07:46 PM
woody31's Avatar
Almost A Senior Member
good luck with the technical ask for help,,seems lacking on this forum unless you are with the IN crowd,,,carry on ....
Old Jun 20, 2014 | 09:56 PM
I'm OUT.. Guess I'll just call the junkyard and have them come get my car
Old Jun 20, 2014 | 10:34 PM
You've been getting technical advice and you've taken steps along the way to care for your car.
No one can not know or answer every question.
Old Jun 20, 2014 | 10:40 PM
I was being sarcastic lol You guys have helped a lot
Check the off topic threads for a spooky one
Old Jun 20, 2014 | 11:00 PM
I did check out the off topic threads. Thanks.
Old Jun 26, 2014 | 02:24 PM
0 Codes thus far with the replacement of plugs, wires, coil
