Loud clank left rear (edit: it's the front)
Old Jun 6, 2006 | 01:45 AM
deserthonda's Avatar
Default RE: Loud clank left rear(edit: coming from front
i am not 100% sure but if it is coming from the frt what you might hear is the brake pad shifting back and forth in the caliper .. if that is the case i am not going to say that it is normal but i hear it in a lot of newer cars ..
let me know what they say,, if it is the pad shifting i am going to let you try a little trick ,, and we will see if it helps
Old Jun 6, 2006 | 02:56 AM
Chiovnidca's Avatar
ORIGINAL: deserthonda
That's usually not much more than a little click though.
Old Jun 6, 2006 | 11:43 AM
ORIGINAL: Chiovnidca
to you and to me .. we would describe it that way,,
but i have learned many moons ago that diffferent people describe noises in a total different way ..and if says that the dealer said it is normal, there would be the first thing that came to mind since i have heard the noise on many cars
Old Jun 6, 2006 | 11:49 AM
RTexasF's Avatar
Super Member
If it is indeed from the front when first starting out in reverse or forward it is likely the ABS system doing its self check. It is common on all 7 the generation Hondas with ABS. It should only do it ONCE, not continuously.
Old Jun 6, 2006 | 01:54 PM
sir_nasty's Avatar
correct me if I'm wrong but when the abs does it self check isn't that more of a "humming/buzzing" noise? I realize that we all have our own opinions/interpetations of noise but the self check I always thought was just the abs pressurizing and it sounds like a buzzing to me...
Old Jun 6, 2006 | 02:22 PM
like i said......... people interpetation of noises, squeaks, rattles. are all different ..
Old Jun 6, 2006 | 03:45 PM
  #17
RTexasF's Avatar
Super Member
Mine is a slight "clunk" no two ways about it. Anyway it's just another possibility of many things that could be wrong.
Old Jun 6, 2006 | 05:22 PM
  #18
longhornjohn's Avatar
deserthonda + others:
I went to the dealer this morning and the mechanic and I verified the clank. We then took another new car from the lot and it did the same thing. The first mechanic then checked with the AT mechanic who told him that all Honda Accords will have the clank when the vehicle has been backed up an incline, transmission put in neutral and allowed to roll forward before putting the AT in drive. The 1st gear apparently does not have syncronizers. I have never heard the clank if I put the AT in drive before releasing the brake.
The mechanic also stated that not all Honda automatics are built that way.
Old Jun 6, 2006 | 08:21 PM
  #19
Chiovnidca's Avatar
ORIGINAL: longhornjohn
Interesting, guess they should have explained that the first time they had it?
cdfixer
Feb 12, 2021 06:55 PM
kc0jsj
Oct 30, 2011 12:22 AM
Lokheed
Mar 18, 2009 04:49 PM
fullybuilt
Jul 7, 2008 11:28 AM
jayhova804
May 19, 2005 02:15 AM
