loud noise when accelerating
Old Oct 27, 2008 | 04:37 PM
stevenb17
Default loud noise when accelerating
i have a '00 Accord and when i accelerate and the pedal is in the right spot i hear a loud chirping or whistling kind of noise. any idea's of what that could be?
Old Oct 27, 2008 | 05:34 PM
falkore24's Avatar
Default RE: loud noise when accelerating
CAI?
Old Oct 27, 2008 | 06:18 PM
stevenb17
i just installed a SRI but it was happening before i put it in. it only got louder after i installed it...
Old Oct 27, 2008 | 10:46 PM
patrickz's Avatar
it could be the air getting sucked in. a sri changes the sound of ur engine. especially under hard acceleration. to check, start ur car with the hood open, have him rev it up and down, and put ur hea near the end of the intake
Old Oct 27, 2008 | 10:56 PM
cjdm98's Avatar
I would inspect all intake hoses, Vacuum,throttle,etc..
Old Oct 28, 2008 | 08:56 AM
falkore24's Avatar
x2 on vacuum connections .... also look at exhaust gaskets for black carbon indicating leakage.
Old Oct 28, 2008 | 04:25 PM
stevenb17
i know it's not the intake itself becuase it was happening before i put it in. i'll make sure to check everything though.
Old Oct 28, 2008 | 05:26 PM
Hobbin's Avatar
Guys I've been procrastinating on posting about the EXACT same problem.
I've been dealing with this high pitched noise for several several months, trying to figure out what it is.
My CAI definitely makes a noise, but it's not the noise I'm talking about. I would describe the CAI noise as a "whistle," where I would call this unknown noise a high pitched "squeal."
Now I've heard loose belts squealing before, and it sounds nothing like this. Just to make sure it's not a belt, I've put pressure on the belts that are visible to see if I can induce the noise or cut it out. Nothing happens. I tried to figure out how to loosen the tension on the timing belt then bringing it back to normal....but I ended up cancelling that mini-project in fear of 'messin up big time'. I don't think it's the timing belt anyways.
What it DOES sound like is a squealing bearing. My first thought when I heard the noise was "Oh, my throwout bearing is going bad." When I found out automatics dont even have that, I lol'd @ my stupidity.
No particular action will induce the squeal, except for when pressure is put on the engine. I mean, when the engine moves. When I pop it into gear from neutral, it squeals like crazy. SOmetimes worse than others. This is what made me think it was something to do with my transmission (since it sounded like a bearing, I assumed throw out bearing). After some studying and messing with it, I found that when I pop it into gear, the engine will move back a little bit, thus causing the squeal. So if it's in neutral and not moving, I can push on the block with my hands (when not hot) and I can induce the squeal.
HAF, what are some steps I can take to help me fix this problem?!
**for the record, I do have a small exhaust leak between my headers and exhaust manifold. I don't think this is the problem though, because the squeal sounds like metal against metal, not a "whistle" sound
Old Oct 28, 2008 | 06:04 PM
falkore24's Avatar
hmmm .... bearing/pulley in the alternator or power steering pump?
Old Oct 28, 2008 | 08:08 PM
stevenb17
with mine it's not when i put it into gear it's when im accelerating and it only happens when the pedal is in the right spot. if i give it more gas the sound goes away and if i take off a little gas it goes away. it's deffinately not the intake. it's a completely different sound. it's hard to explain what it sounds like other than a chirping kind of noise.
