Low idle and stalls in d4 and reverse
Old Nov 19, 2011 | 08:09 AM
If you can't get any compression in cylinder, valve damage is likely. Usually worn rings will generate some compression but low and cylinder will fire w/ pretty low compression. Valve damage seems more likely.
Make sure cylinder is getting fire before checking compression. No fire is even more likely reason for cylinder dead miss.
Old Nov 19, 2011 | 06:47 PM
mishakol129's Avatar
How can I tell if the valves are damaged?
Old Nov 20, 2011 | 06:10 AM
Very low or no compression is first indicator and 2nd is to inspect the valves for excessive gap (up to 1/4" perhaps) between rocker arm and valve stem.
Accordguy1999
Apr 16, 2015 10:50 PM
88hondaaccord
Oct 8, 2012 06:37 PM
Nitin
Apr 20, 2008 07:19 PM
HondaAccordNewb
Oct 18, 2007 06:51 AM
kevcann3
Aug 14, 2007 05:15 PM
