main relay
yeah i have a 94 lx just changed distributorm,coil,plugs,wires,cap,rotor and the cuts out when revving engine rpms and speedo surge and main relay is going crazy im thinking its the ecu havent found any shorts yet anybody have this or experienced this type of problem
Your post was difficult to read.
If the MFR is going crazy (clicking), then I suspect that your ignition switch is likely worn out. Try turning the key a bit while the car is running. If it stalls, then the electrical portion of the ignition switch is faulty.
