Maint Req'd light
Old May 13, 2008 | 08:24 PM
Accord Owner's Avatar
Default Maint Req'd light
How do I turn this light off?
This does not really mean I need maintenence right?
Old May 13, 2008 | 08:33 PM
poff1986's Avatar
Default RE: Maint Req'd light
Whats your mileage? To turn it off, turn key completely off but leave in ignition, hold the trip odometer reset switch in and continue to hold while turning the key on, the light will either blink or stay on steady for about 10-15 seconds, then it should turn off, once it does you can release the trip reset switch
Old May 13, 2008 | 09:01 PM
ORIGINAL: poff1986
around 49,500.....What do I need to get done?
Old May 13, 2008 | 09:05 PM
I bought the vehicle at 40K in 2007. All I have been doing is Oil and Filter changes.
Old May 14, 2008 | 09:14 AM
falkore24's Avatar
It's just a milage timer. The reset directions above are correct. Look it up in the owner's manual for peace of mind. Also, please add vehicle info to your profile signature, then check the "add signature" box when posting questions.
Old May 14, 2008 | 09:17 AM
JkillaAcc02's Avatar
dude just reset ur milager thing its telling you to get an oil change and once u get the oil change u reset the milage counter
Old May 14, 2008 | 11:06 AM
ORIGINAL: falkore24
Did not get the manual when I bought the car.
Ok
Old May 14, 2008 | 11:07 AM
ORIGINAL: JkillaAcc02
I just got a oil change, I do this every 3K miles.
How can I programmed it to come on every 3K miles then?
Old May 14, 2008 | 11:23 AM
falkore24's Avatar
I don't think you can program the maintenance light on Hondas.
Old May 14, 2008 | 02:07 PM
I've never heard of a way to program it to go off sooner. Further, you can't clear it if it's not yet going off. If you change oil early, and the warning isn't going off, you can't clear it.
