Maint req'd light
Old Jan 27, 2009 | 04:44 PM
deadhand
Default Maint req'd light
Mine is flashing 10x when I start the car, then it stays off till I start it again. Any one know what it is?
Oh yeah, its a 99 4 door with a v6.
Thanks in advance!
-Jon
Old Jan 27, 2009 | 04:51 PM
Carebear_ehs89's Avatar
Default RE: Maint req'd light
how many miles does it have?
Old Jan 27, 2009 | 04:55 PM
Means its getting close to oil-change time.
Its a reminder for every 7500 miles, regardless of any actual measured performance. A few hundred miles early, it flashes like you say. Then it comes on solid & stays on.
Reset like this...
Key switched OFF.
Press & hold the odometer reset button.
Key ON while you continue to hold the reset button (no need to actually start the engine).
Continue to hold that button forever. No wait, its just about 20 seconds.
Itll blink a few times then go out.
Now itll stay off for the next 7500.
Old Jan 27, 2009 | 04:56 PM
finch13's Avatar
It's telling you its close to 3,000 miles since it was last reset (it's basically and oil change reminder), soon it will stay on.
To reset it:
1. Put the key in the ignition
2. Hold down the trip reset button
3. Turn the key while still holding the button
4. The light will go off after about 10 seconds
Old Jan 27, 2009 | 04:58 PM
my mnt. req light came on at about 100k it was for the 100k dealer check up thats why i asked i had the car for about 15k b4 that and it never once flashed at all untill close to the 100k
deadhand
OMG, this forum rocks! Thank you guys! I'll try it and post up the results. Come to think of it, it is getting to be time for an oil change
Old Feb 24, 2009 | 01:36 PM
joltheadq
Default Make sure your headlights are off
I have an '05 Honda Accord Hybrid. I left my headlamps on while attempting to clear the maintenance required indicator ending with "no go." After calling the dealership, I was informed the headlamps must be off in order to clear the mant req'd lamp. Hope this helps.
Old Feb 24, 2009 | 03:55 PM
Welcome new member joltheadq!
The newer cars (with maintenance-minder) have a little different procedure anyway. That's one more reason why it's important to say exactly what car you have.
Yessy Consuegra
Mar 8, 2014 02:55 AM
LONO100
Apr 17, 2012 05:41 PM
Accord Owner
Mar 11, 2010 08:47 PM
Jeffmo
Aug 19, 2007 08:17 PM
mrmookie123
Apr 7, 2007 03:19 PM
