"Maintenance required" .. What color should it be?
Old Jan 15, 2012 | 12:13 AM
93Accord2.2's Avatar
Default "Maintenance required" .. What color should it be?
I never saw this before, but I now see that it has this.. and it looks like it's yellow... is that thing a light? What is that thing? I only need to check the codes if the actual red CEL is on, right? If I do need to check them anyway it is under the passenger kick panel and you just jumper it like you would on a chevy?
Old Jan 15, 2012 | 08:30 AM
Maint Req is a remider that you need to have "some service" done. On this gen I think it is a simple "counter" that reminds you to change your oil.
Old Jan 15, 2012 | 08:34 AM
Poorman is correct it just changes color every 3,000 miles I think. If you look right next to it on the cluster there is a little black button. You will find your key fits perfectly into the button and will reset it to green.
Old Jan 15, 2012 | 02:29 PM
EXV6NIGHTHAWK's Avatar
I think it turns yellow, at a certain mileage, then red, after additional miles. It's only a reminder to do the maintenance, so nothing is wrong with the car. The Check Engine Light (shaped like an engine) would mean there is a problem, and there are codes stored. Like he said, push your key into the little slot next to the light, and it will go back to green.
Old May 2, 2012 | 07:03 PM
Nitehawk Girl's Avatar
This has started happening to my car, and panic ensued until I started reading these posts.. Thank you for calming me down lol.. I'll try that trick tomorrow...
Old May 2, 2012 | 07:14 PM
For your 2003, it's a slightly different reset procedure. I'll look it up and post it for you; but, it is in the owner's manual.
Old May 2, 2012 | 07:17 PM
This is for the 2003 Accord, see image.
Attached Thumbnails "Maintenance required" .. What color should it be?-indicator.jpg
Old May 3, 2012 | 05:17 AM
Thank you! I don't have an owner's manual as of yet, my car didn't come with one.
Old May 3, 2012 | 09:54 PM
Update! The reset worked! My light is off! And my stress is gone! .....until next time...lol
azdrake
Nov 4, 2013 07:03 AM
Sparco_racingVTEC
Jul 17, 2009 12:22 AM
customcreazn
Feb 13, 2007 11:40 PM
Daveyjones
May 30, 2006 10:17 AM
hotrod01
Nov 11, 2005 01:28 AM
