major oil leak in driver front corner of engine.
Old Oct 12, 2011 | 03:37 AM
cutlass327's Avatar
Well, ordered the seals (cam, crank, shafts), belts, etc. today at O'Reilly's. The balance shaft seals come with the retainer.
Thought of the WP, but it was done when I did the timing belts the last time - that is why I did them, it puked, and I believe it will be ok until next time around. I don't see the car lasting til next winter anyways, it is starting to rust faster than before, and with 335k on it, it's starting to show it's age, more than I want to try to keep up with. I was just wanting it to get thru this winter and I'd be happy, but this happened. Not even winter yet!
Old Oct 12, 2011 | 01:56 PM
cutlass327's Avatar
Took forever to get that front balance shaft sprocket bolt out. Had to put a screwdriver thru the hole, a pipe over its handle, and an extension on the ratchet handle. I couldn't get both hands down in there to hold one and turn the other.
Still haven't gotten my parts, took to long fighting that bolt - over an hour! Sad, sad, sad... I'm losing my trick on cars, heavy trucks are much easier!
I'll keep this updated as I go, in case anyone else runs into this. I have yet to search for the seal install tricks. Hard to do from my phone..
jza240sx
Apr 30, 2013 04:14 PM
nocode
Jul 23, 2012 05:53 PM
timmiegee
Jun 6, 2009 04:51 PM
ahntrio3
Nov 5, 2007 06:15 PM
HoopAccord
Nov 10, 2006 01:32 AM
