2003-2007 Engine
Old Oct 12, 2011 | 09:02 AM
MaxyMax's Avatar
Default 2003-2007 Engine
Hey,
I have a question and I hope to find the answer here.
I have Honda Accord LX 2003 2.4L, and I need to put a new engine in it. I found a 2007 engine in the area I live in. The question is: Can I put a 2007 engine on a 2003 Accord?
Thanks for the help in advance.
Old Oct 12, 2011 | 12:03 PM
MaxyMax's Avatar
Anybody please? No?
Old Oct 12, 2011 | 12:20 PM
You can; but, I'm not sure of what all may be involved for the swap.
In the 2003, I believe it still has the cruise control and throttle cables. Whereas, the 2007 went to drive-by-wire throttle control which was electronically controlled.
My guess is if you swapped the block and used the same intake manifold (may or may not need to swap intake manifold) and throttle body, that would be the easiest. If you were trying to swap everything, then that may require a different ECM/PCM, pedal position sensor, etc., etc.
I'll see if I can find anything.
Old Oct 12, 2011 | 12:26 PM
Intake manifold is different.
Old Oct 12, 2011 | 12:49 PM
MaxyMax's Avatar
Thanks redbull-1, I really appreciate it. I will be waiting for any details you also might have.
Old Oct 12, 2011 | 02:30 PM
Your 2003 engine is a K24A4 (2003-2005 Accords), the 2007 engine is a K24A8 (2006-2007 Accords). The cylinder block and head are slightly different between the A4 and A8.
Here is a link of an actual swap done; but, doesn't go into much detail.
"http://www.v6performance.net/forums/7th-generation-honda-accord-2003-2007/197812-engine-blew-up-so-i-swapped-new-one-pics.html"
Copy and paste without the quotation marks (" ") to see link.
Old Oct 12, 2011 | 04:15 PM
MaxyMax's Avatar
Thumbs up
wow that is very informative, can't thank you enough man!
RangerRuss
13
Jun 1, 2011 11:58 PM
stiege
Mar 22, 2011 12:02 AM
MtZauch
Dec 18, 2009 03:05 PM
Stxdpc
Sep 6, 2009 01:49 AM
