massive oil consumption @ highway speed
Old Jul 27, 2013 | 08:22 AM
slowride66's Avatar
Hey Y'all
I will check the codes asap
I feel kinda stooopid that it was easy to find once I help my lips just right.
I threatened a lot worse on this lil forker
I worked 15+ years in the auto salvage indusrty a really morbid sound a engine block makes when crushed in a press
Torches air hammers bolt cutters & a K~10 gas powered 14" abrasive saw & this lil forker will bother me no more!
Insert evil laugh here
thanks so very much
SR66
Old Jul 27, 2013 | 08:49 AM
Once you get them. You can clear them by pulling the "back up/ECU" fuse from the underhood fuse box. Pull it, wat a few seconds and re-install......done
Old Aug 12, 2013 | 11:00 AM
slowride66's Avatar
still have not made time to look at codes.
I can tell you its now leaking some oil.
perpetual oil change
SR66
Old Aug 13, 2013 | 07:31 PM
Well, IMO - leaks are easier.
Can you give us any clues as to where the leak is....behind the block, left drivers side of the engine, right pass side of the engine?
And just me, nice to know the PCV was a "fix" to your other issue - been there, done that and gave me a smile to know.
Old Aug 28, 2013 | 07:08 AM
slowride66's Avatar
So crazy buzy its on my hit list today flashing led under seat.
thanks for all the help
SR66
Old Sep 2, 2013 | 02:00 PM
slowride66's Avatar
LED blinks 12 times.
SR66
Old Sep 2, 2013 | 03:10 PM
  #17
I hate that one on these. EGR issue of some "sorts".
Clear the code(s) - pull the fuse from the underhood fuse box.
This is where you call me crazy. Be sure to clean the neg battery cable....at the battery, where the bolt goes to the body....just beside the "tray".....and where it goes to the trans.
Drive the car for a bit and see if the code comes back.
Old Sep 2, 2013 | 04:00 PM
  #18
slowride66's Avatar
OK Crazy
I will do it
LOL!
SR66
Old Sep 4, 2013 | 10:24 AM
  #19
slowride66's Avatar
the code is still there .
Not sure if I have mentioned this before.
Check engine light used to come on intermittently shut off key & would go away
now about 3 miles & its on & burning ,PLUS
I drove it to airport with light burning & when I got there the temp was in the red on high.
was not low on coolant but the passenger side fan is not running switched relays with power windows & the relay works but no fan.
I will try to power it up with my power probe later today.
At highway speed would that fan even matter?
It did not boil over
UGH! now what?
Thanks
SR66
Old Sep 5, 2013 | 06:01 PM
  #20
We can get back to the CEL.....the overheating is #1 now.
Does sound like the fan motor has gone.....as you said, put 12v to it and see if it works.
Once you get that sorted out, we can get back to the CEL.
