Master Cylinder replacement...
Old Aug 5, 2011 | 06:24 PM
MessAround's Avatar
Almost A Senior Member
Default Master Cylinder replacement...
If I'm replacing a master cylinder because of the issue where the pedal gets spongy or travels too far down on hot days only, do I need to change the fluid too? Or does the issue mean the fluid is fine but the cylidner itself is the problem? Does the heat affect the seals or something?
I ask because the 95 has its wheel cylinders replaced because one was leaking brake fluid. The fluid was changed as well afterwards. But the spongyness on hot days is still there so the master cylinder is going to be done next.
Old Aug 5, 2011 | 07:53 PM
You will lose some fluid while changing the MC and will have to bleed the brakes (more fluid loss). You will need perhaps 1/2 pt of brake fluid.
Old Aug 5, 2011 | 08:25 PM
Thumbs up Hello Member
If your fluid is old and looks like the color of there words I'm typing..then I would suggest retireing it to the re-cycle people...
On another note , I like this color of letters better...
Attached Thumbnails Master Cylinder replacement...-81-5471-01haccd1996%7E97.jpg
Old Aug 6, 2011 | 12:21 AM
EXV6NIGHTHAWK's Avatar
A bad master cylinder will usually cause the brake pedal to slowly sink to the floor. Spongy brakes are usually caused by air in the lines. Who changed the fluid, and bled the brakes?
ZMan3000
May 22, 2008 02:57 PM
aso432
Oct 25, 2005 02:02 PM
aso432
Oct 23, 2005 10:41 PM
gonecrazy
Oct 12, 2005 11:57 PM
gonecrazy
