Missing DTC data
Old Mar 23, 2015 | 09:41 AM
CoolUncle's Avatar
Default Missing DTC data
I plugged my OBD II diagnostic meter into my 2002 1.8 sport to try and reset my CEL after having sorted the problem.. Is it possible to erase all the diagnostic data that was programmed into the car originally..? The car won't start now..
Old Mar 23, 2015 | 10:10 AM
CoolUncle's Avatar
The problem I sorted was to change the vtec solenoid., as that uses pressure could the fact that I changed it therefore de-pressurising it be the reason the car won't start until the pressure is back to normal..? I presume turning over the engine will increase the pressure..?
Or am I miles out an have wrecked my car..
Old Mar 23, 2015 | 05:58 PM
Vtec system is unlikely the cause of no-start.
Suggest listening carefully when keyswitch is turned to On for fuel pump in fuel tank to run for 2-3 secs and go off.
If you don't hear the fuel pump, the main fuel relay or fuel pump are likely faults.
If you hear fuel pump when no-start condition is present, the ignition fault (ignition switch, ignitor, or coil).
See following link for additional diagnostics:
Honda Acura Starting Problems Repair Guide, Main Relay Locations
77Impala
Jan 29, 2010 09:53 PM
dizzle'95
Feb 23, 2009 03:53 PM
adbraz
Sep 29, 2006 07:00 PM
mwierm
Oct 14, 2005 01:52 PM
