Moonroof will not open
Old Nov 23, 2013 | 11:24 AM
Accord368's Avatar
Default Moonroof will not open
2003 Honda Accord moonroof will not open.....worked one week ago. Fuse looks good what else could be wrong?
Old Nov 23, 2013 | 08:09 PM
  1. Is this a coupe or sedan? The moonroof circuit is slightly different between the two.
  2. Was it the No. 28 (20A) fuse you checked in the under-dash fuse box?
Old Nov 24, 2013 | 04:42 PM
Accord368's Avatar
1. It is a sedan.
2. We checked No. 28 (20A).
Old Nov 24, 2013 | 04:48 PM
If fuse was good, carefully push out the moonroof switch from behind the dashboard and disconnect the 6P green connector from the switch.
  • With a spare piece of wire, touch one end to terminal 6 (Gry/Blu wire terminal) and the other end of the spare piece of wire to body/chassis ground with the ignition to ON. (Only do this briefly) Does the moonroof open?
  • If it does open, repeat the same procedure I mentioned; but, this time instead of touching the other end to body ground, touch it to terminal 3 (Blk wire terminal). (Only do this briefly) Does the moonroof still open?
Old Nov 25, 2013 | 10:46 AM
Just to clarify, so you don't break anything; from behind, you will push the moonroof switch out the front of the dashboard.
dacecil
Sep 24, 2007 11:50 AM
dhoff
Jul 17, 2007 10:47 PM
Jenerator
Nov 6, 2006 04:24 PM
ozman05
Apr 20, 2006 01:31 PM
