Motor Mounts + Transmission Mount Replace
Old Nov 30, 2022 | 02:58 PM
btartus's Avatar
Originally Posted by plenum
Oh by the way, when you change the motor mount. I think you need to support the transmission or the motor with a jack and piece of wood. Also, about the transmission fluid, you could be okay to do a drain and refill. Not a flush, you would be replacing only about 30 to 40 percent of the fluid. If the fluid is clean its probably okay to do at least a drain and a refill. Ask a mechanic about that to see what his opinion on it is. The rumor that transmission fluid ruins a transmission is probably from someone using a low quality transmission fluid or not the wrong type. So the clutches probably wear out more. And that also that if the transmission fluid is dirty its using that old material already with a worn out clutch and so when you replace it the clean fluids causes the transmission fluid to slip because it doesn't have the old fluid to bind to. Again, do your research on this and ask your mechanic just in case.
sound great! thanks again! really appreciate all the advice!
bt
mrg2065
Aug 24, 2020 07:21 PM
slickgeek
Dec 21, 2014 12:36 PM
Florida_Frank
Oct 25, 2013 04:47 PM
c0r3f1ght3r
Dec 15, 2010 11:21 AM
Mpwr
May 30, 2006 11:18 PM
