MOTOR SWAP
Old Jan 29, 2008 | 08:30 PM
cowboy from
Default MOTOR SWAP
swaping my 97 motor (blown) with a 96. same model and all just diff years. it should work right? only difference i can see is the coil (or whatever its called where ur spark plugs go) on the 97 the main one 5th has a hole for it on the coil on the 96 i dont see the hole. cant find where it goes. help
Old Jan 29, 2008 | 10:18 PM
Default RE: MOTOR SWAP
Perhaps what you mean is the '96 has an internal coil. The coil is located inside the distributor, so there's no place on the distributor cap to plug in the coil secondary wire.
Old Jan 30, 2008 | 07:42 AM
cowboy from
distibutor? oh my bad i thought these had on of those distributorless ingnitions like my rx7 wow i feel dumb[&:]so in other words will a 96 f22 work in a 97 accord? iam using my 97 trans ecu etc. so will it drop in no prob?
Old Jan 30, 2008 | 07:56 AM
Use your '97 distributor on the '96 engine?
Old Jan 30, 2008 | 09:09 AM
cowboy from
ok.didnt know if i could do that.thanks for the help.[sm=thanx.gif]
Old Jan 30, 2008 | 01:24 PM
nafango2's Avatar
if his 96 has an internal coil, why doesnt mine?
i definetly have an external coil, and definetly have a 96. wth?
also, what year is your rx7?
Old Jan 30, 2008 | 10:09 PM
I didn't bother looking up which years were internal or external. Just took his word for it...
Besides, if you use your existing ECU & wiring harness, then using the matching distributor would make some sense anyway.
Old Jan 31, 2008 | 12:48 PM
cowboy from
got a 96 single cam non vtec.least thats what the vin numbers say.
Woodall
Mar 4, 2014 04:21 AM
Doublel
Mar 11, 2013 07:57 AM
brennonm
Sep 1, 2008 10:42 AM
accord4sroy
Aug 22, 2007 11:24 AM
projectaccord96
May 28, 2006 11:17 PM
