Was my original motor ULEV?
Old Nov 7, 2012 | 02:04 PM
beateraccorddriver's Avatar
Default Was my original motor ULEV?
Hi, i recently bought a 1999 accord ex 4 cyl 5 speed, and the previous owner put in a 2001 ULEV motor.. Im getting an engine code p0135 (pre-cat o2 sensor).. could anyone tell me if the original motor was ULEV or not? the VIN for the vehicle is 1HGCG3154XA011884
Old Nov 7, 2012 | 02:48 PM
The original motor based on the VIN was not a ULEV. The trouble code also indicates the ECU was not for a ULEV, as that code is for a regular O2 sensor instead of an air/fuel ratio sensor used for the ULEV.
Old Nov 7, 2012 | 02:59 PM
Thank you! that is what i thought but thanks for the confirmation. Im thinking that if i got an air fuel ratio sensor with the current ecu the light may go away? or would i have to swap the ecu for a ulev ecu? any thoughts on this?
Old Nov 7, 2012 | 03:12 PM
If the ECU is not for the ULEV, it should only need the regular O2 sensor.
There should be no need to swap ECU, which would also be a pain due to reprogramming needed because of the Immobilizer.
The car may just have the F23A4 block from a ULEV (and maybe the cylinder head), which is essentially the same as the F23A1 (non-ULEV). The person that swapped it probably kept some of the F23A1 parts, which makes your current engine for the most part, like a F23A1.
Old Nov 7, 2012 | 03:57 PM
Check your other thread. The big difference is the exhaust manifold, and we can hope the previous owner used the non-ULEV manifold.
There's substantial differences in the car's wiring harness too, so that makes it even more difficult than just getting a ULEV ECU.
Ive seen more than one thread where someone found a ULEV engine for cheap, so they turned it into a non-ULEV engine by swapping the exhaust manifold. That's easier than converting the CAR over to ULEV.
jhillblessed
May 10, 2010 09:55 AM
YeuEmMaiMai
Oct 22, 2006 12:27 PM
Staged206K
Oct 18, 2006 01:20 AM
thunder_x
Aug 2, 2006 09:55 PM
stretchpdx
May 29, 2006 05:15 PM
