need advice - water pump inlet tube
Old Feb 3, 2007 | 08:58 PM
oldaccordman
Default need advice - water pump inlet tube
Hello all,
New to the site, but love my Accord . Currently 237,000 miles on the LXi
Here's my question.
The water pump inlet pipe began leaking today in my '89 FI Accord. Since I have to replacethe pipein my driveway, is this going to be a real pain to replace from the top of the engine ? Or is it easier from under the car reaching up ? Our 16 degree weather here won't help !
Hope someone can steer me in the right direction since I don't want to freeze to death doing it !! : )
Old Feb 4, 2007 | 01:00 AM
hondadude's Avatar
Default RE: need advice - water pump inlet tube
You are going to freeze your[sm=smiley35.gif] off .
Find someone with a garage that owes you a favor; or bribe them with beer
All the stuff on the T-stat end of the tube can come off from above, there is a 10mm bolt thru a 'strap' attached to the tubeon the back of the block [drivers side of the differential area.]
From underneath there is a support bracket for the intake.
It will help if you spray that area where you are trying to pull the tube out of the back of the water pump, with some silicone. That will help the old rock hard 'O'ring come out easier. After you jerk and tug the tube out clean that area as well as you can. I usually smear the new 'O' ring with dow corning 111 silicone grease to help it seat and seal.
I just don't think I'd try this job outside on the ground in freezing temps.
Then again I don't check tire pressure without raising the car on the lift LOL
Old Feb 4, 2007 | 01:13 AM
poser_pilot6
Hey, if you live anywhere close to Clarksville, you can bribe ME with beer... Okay, so I have nothing to contribute to this post. But I do enjoy hondadude's signature. It cracks me up.
Old Feb 4, 2007 | 12:27 PM
oldaccordman
Thanks for the info .. I'll just have to get it inside on a lift.
Old Feb 4, 2007 | 04:46 PM
deserthonda's Avatar
ORIGINAL: hondadude
You are going to freeze your [sm=smiley35.gif] off .
All the stuff on the T-stat end of the tube can come off from above, area.]
the t-stat stuff on the 89 accord is at the end of the top radiator hose,( t-stat housing D-gasket ) ,,,,, at the end of the water pump tube , there are just hoses ..And yes i totally agree with the Dude do it from underneath and mostly, find a warm place to perfrorm the work and don;t forget to bleed the system when job is done ..
capthoward
Jul 13, 2011 04:34 PM
piggylover1985
May 27, 2011 05:28 PM
creator1322
Dec 6, 2010 03:40 AM
desfam5
Aug 23, 2010 03:33 PM
thunder_x
Jul 13, 2007 04:20 PM
