Need ECU, HELP!!
I have a 96 Accord F22B1 VTEC with an auto to manual swap and fully rebuilt engine. I do all my work myself I need an obd1 or 2 ecu with vtec that is for a 5 speed can anyone tell me what ecu i need? or would it be better to use the f22b1 AT ecu i have? need help thanks
X2. They're not very expensive. I have read that the auto ECU can be converted:
This is a very simple conversion. Move the SMD 0 ohm resistor from location RP13 on the bottom of the PCB to location RP14 on the top of the PCB. The 0 ohm SMD resistor is identified by code 000 etched on it.
That's from PGMFI and it's for a P5 Prelude ECU, but post #82 in this thread:honda-tech(dot)com/showthread(dot)php?p=48791807
...says it works on a P0J ECU, which is a non-VTEC OBD2 Accord ECU. If it works on a P0J, there's a good chance that it will work on a P0H.
live2rice
Sep 20, 2012 02:26 PM
94AccordEXThesleeper
Dec 13, 2010 08:08 AM
