Need to find fuse on 95 accord
Old Mar 14, 2011 | 11:16 AM
justin21x's Avatar
Default Need to find fuse on 95 accord
Hey there,
Recently bought a 95 Honda accord 4dr EX 2.2L . The signal lights were working fine when I got it, after 2 days they're not working. I'm thinking it's the fuse. I do not have a owner's manual. I found both fuse boxes, but the fuse I require is under the steering wheel and there is no panel saying which fuse is what. I need to locate this fuse, if you could tell me where it is with a diagram, or good description it would be great! Also the hazzard's dont work, but that fuse is located under the hood and it is fine.
Old Mar 14, 2011 | 11:53 AM
muffinman617's Avatar
This is the compenant identification chart for the fuse box under the dash(from mitchell on demand), there weren't any actual photos or diagrams. as you can see the turn signal fuse is(i assume) the bottom most fuse? hope it helps.
UNDERDASH FUSE/RELAY BOX COMPONENT IDENTIFICATION
Fuse No.
Amps
Component Or Circuit Protected
Gauge Assembly, Back-Up Lights, Clock, Vehicle Speed Sensor (VSS), Shift Lock Solenoid
PGM-FI Main Relay, SRS Unit
SRS Unit
Charging System, Transmission Control Module (TCM), Radiator Fan Control Module, Cruise Control, PGM-FI
Not Used
1995
Rear Wiper/Washer
Wiper/Washer
Anti-Lock Brakes (ABS), Power Mirrors
Air Delivery, A/C Compressor Controls, Fans, Rear Window Defogger
Gauge Assembly, PGM-FI Main Relay, Engine Control Module (ECM)
Daytime Running Lights Control Unit (Canada)
11
Cigarette Lighter Relay
12
7.5
Turn Signal/Hazard Relay
Old Mar 14, 2011 | 12:09 PM
justin21x's Avatar
Is this the right thing? Seems like I got way more fuses in my panel then that, and I don't have a rear wiper, my model isn't the wagon.
Old Mar 14, 2011 | 01:12 PM
You can download a 94 shop manual from the online manuals thread in the DIY section. That will give you a description of the fuses and locations.
Old Mar 14, 2011 | 07:04 PM
justin21x's Avatar
I can't find the location to where you're speaking of. Can you send me a direct link?
THanks
Old Mar 14, 2011 | 07:14 PM
You probably have to change the display options at the bottom of the DIY forum to see old threads.
The 94 is the third one in this list. Just copy and paste into your browser.
hondatech.info/downloads/Auto/Manuals/Accord/
Old Mar 14, 2011 | 07:37 PM
justin21x's Avatar
I found it thanks a lot.
I'm not sure if this will be of help either as it does not look 100% like my fuse box. I found the diagram showing the under dash box.
Old Mar 15, 2011 | 10:41 AM
justin21x's Avatar
I found the diagram for my 1995 honda accord from someone's owner's manual!
Here it is if other people out there ever need it.
This is the in dash fuse box diagram for a 1995 honda accord lx/ex
Old Jun 29, 2012 | 06:19 AM
Gurkin's Avatar
anyone got the diagram for the fuse box located in the engine bay. This would help a lot
Old Jun 30, 2012 | 08:26 AM
You can download a manual for it.
There is a sticky right at the top of this section that has links to it:
https://www.hondaaccordforum.com/for...threads-40780/
Attached Thumbnails Need to find fuse on 95 accord-5th-gen-fuse-panel-underhood.jpg   Need to find fuse on 95 accord-5th-gen-fuse-panel-underhood-numbers.jpg
KayakingAccord
May 25, 2022 03:27 PM
dunnskii
Aug 12, 2010 10:43 AM
Jayson Wonder
Jan 24, 2006 10:31 AM
netanderthal
Jan 20, 2006 06:33 PM
maximyshka
Sep 30, 2005 05:25 PM
