Need Help!! 08 V6 honda accord coupe making load noise...
Old Feb 27, 2013 | 11:40 PM
frivera04's Avatar
Default Need Help!! 08 V6 honda accord coupe making load noise...
hi guys.. need help..just bought a used honda accord... love the car until it started making this loud noise......after driving the car... and im on neutral and parked while the car is running... the car made this really load noise... like a roaring noise or a water hose noise (it seem like its coming from the engine) ... it would go on like 4 time (really loud).. and then stop...and i would see some smoke too (but check engine light is not on) ..and it would have a weird smell... the car runs fine..but i did seem to notice that the idle did kind of go up and down (not really noticeable)... has this problem ever happen to you? any suggestions
Old Feb 28, 2013 | 11:46 AM
Open the hood & watch; where's the noise exactly?
Turn off the airconditioning. You'll also have to direct the ventilation down to feet, because when defroster is selected it runs the AC. Does it still do it? I'm thinking something related to problems with AC compressor.
Old Feb 28, 2013 | 04:09 PM
frivera04's Avatar
Yea.. I turned of the AC... And there's a weird hissing noise coming from the AC... I can hear from the inside of my car.. maybe there is a vaccumm leak somewhere
Old Feb 28, 2013 | 04:10 PM
frivera04's Avatar
When i opened up the hood..The noise is coming from the passenger side... a hissing noise that won't stop... Near the steering hose... (Maybe) it's hard to figure exactly where the noise is coming from
Old Feb 28, 2013 | 04:51 PM
Roader's Avatar
Get a two- or three-foot piece of garden hose or the like, hold one end to your ear and the other end to the area where the noise is coming from. You should be able to pinpoint the noise.
Old Feb 28, 2013 | 09:03 PM
Accessory drive belt on a V-6 is on the passenger side, so AC compressor, PS pump, etc are all over there. Don't get the hose or fingers caught up in the spinning belt. I don't remember if the V-6 water pump is driven by the external belt. If not, you can remove the belt & run the engine for a little bit.
Or just remove the belt anyway, and spin each pulley to see if one isn't nice & smooth.
faran
Feb 20, 2017 12:20 AM
rags
Mar 14, 2011 04:16 PM
cowsgonemadd3
May 12, 2010 01:48 AM
MrGmo
Dec 9, 2007 03:34 PM
JDMlx
Aug 9, 2007 12:30 PM
