Need HELP!
Old Jun 26, 2007 | 01:01 PM
u dun 4
Default Need HELP!
Hey guys I need help. 94 accord and problem is that my light where my tachometer and MPH is dim unless im accelerating. I turned the light all the way up but I want to make it stronger. Also I took my car to a shop and they informed me that for $200.00 they can fix my left front tire rod and something about a rack and pionion. And they stated that the bearing is bad on my passenger front side. thats why I feel a lil bit of rubbing and definately shaking when I accelerate and deccelerate. Is that about right. Also am I able to do any of these fixes my self or able to find lesser prices. Please advise.
Old Jun 26, 2007 | 02:27 PM
sir_nasty's Avatar
Default RE: Need HELP!
If the light is dim except under higher RPM's then check your Alternator and make sure that it's giving you a good output (dash light problem). As for the tie-rod and rack and pinion it depends on what's wrong. As for the Bearing I believe they require a press to remove and replace them, are they quoting $200.00 parts/labor to fix all of that?
Old Jun 26, 2007 | 08:40 PM
u dun 4
Well I found out that the inner left tire rod needs to be replaced and the right bearing needs to be compressed on. They said 200 dollars and someone else told me it would be best to get a alignment to because its not going to ride nice after I get the work done.
99accordf23a5
May 6, 2014 12:51 AM
brandyn
Nov 26, 2013 05:31 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
ryan ortego
May 19, 2005 06:06 PM
