Need help with 1998 Accord EX with DTC P1382
Old Jun 14, 2012 | 04:16 PM
pani's Avatar
Question Need help with 1998 Accord EX with DTC P1382
Honda Accord 1998,EX,4cyl, 2.3L,VTec,AT,F23A1
Hi friends,
I need your help. The DTC P1382 is driving me crazy!
After replacing my dizzy with a new one because the old one was leaking oil and the car was runing erratically, the CEL came on with P1382. When installing back the old one, P1382 comes back.
What I have done so far:
-Checked the timing and it is OK
-Measured the resistance between CYPP and CYPM on the male side plug of the dizzy and it measures 847 Ohms
-Checked for continuity between body ground and dizzy there is no continuity
-Measured resistance between PCM connector terminals the black and yellow wires. 847 Ohms
-Checked for continuity between body ground and PCM connector terminal (CYPP yellow wire). No Continuity.
-Changed spark plug wires
Can someone tell me what else to check or do I have to suspect the PCM or can it still has something to do with the timing or something else?
Old Jun 15, 2012 | 06:05 PM
My only two cents, you are close to the bottom (847 vs 800)....humm
After that, yes you have done all of the tests called for and the last thing is a known good PCM and recheck...
Old Aug 14, 2012 | 08:53 AM
Roadkingat55's Avatar
Default P1382
I have the same code P1382. I've been told "crank position sensor" and also "cylinder position sensor". Which is it? One is in the distributor and the other behind the timing chain cover.
Old Aug 14, 2012 | 11:07 AM
My list gives P1382 = CYP sensor no signal
so it's in the distributor for 1999.
I think those signal wires coming from the distributor are shielded, so be careful how you probe them.
RedBoneVirgo85420
Apr 13, 2015 01:05 PM
rockhoundrob
Apr 1, 2015 10:08 AM
mack89
Jul 12, 2013 01:36 AM
falon871
Mar 3, 2011 09:41 PM
thirdgoat
Jan 10, 2008 08:46 PM
