Need help
Old May 19, 2009 | 07:51 PM
gohmdol
Default Need help
Wussup guys i am new to this site...
Got a question i got a code of p0506 which is an idling code of a low rpm... Is there a way i can boost the rpm power? I know the first thing is to clean the fujita intake that i have any other 0ptions?
Old May 19, 2009 | 08:05 PM
Talking Hi New Member
If your wondering how you got over here..then You need To know it was I that moved you Here..This is the correct forum for the question you asked...
P0506 is an IAC (idel air control)a circut condition or idel speed which is higher or lower than expected thru the computer.
Probable Causes can be an engine vacume leak, the IAC motor being defective, having a dirty throttle body, and last of all you could have a silly loose connecter on the IAC..Check it out...
Old May 20, 2009 | 07:12 AM
I guess since it's an OBD-2 code, it must be 1996 or newer. But it would really help to actually know what it is. 2008 4-cylinder is a lot different from a 1996 V-6 which is a lot different than a 1996 4-cyl...
99accordf23a5
May 6, 2014 12:51 AM
brandyn
Nov 26, 2013 05:31 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
ryan ortego
May 19, 2005 06:06 PM
