need help
Old May 10, 2012 | 10:51 AM
eg6civic's Avatar
rrrrrrrr this sucks ok thanks so 94 to 97 right thanks
Old May 10, 2012 | 11:29 AM
crispin's Avatar
yea man it kinda sucks but Honda put the anti-theft so deep into the ECU that it cannot be bypassed on the 6th gens.
Old May 16, 2012 | 06:22 PM
eg6civic's Avatar
can u change the shift cable on the transmision on the 96 i found a 97 but when i try to take the motor out i broke the cable is there a way to chang the shift cable its a auto
Old May 16, 2012 | 06:33 PM
crispin's Avatar
yes you will need to replace it from where it goes to the trans to the shifter in the center console.
Not too hard
Old May 16, 2012 | 06:34 PM
eg6civic's Avatar
thank u god i though it was going to be hard
Old May 16, 2012 | 06:36 PM
eg6civic's Avatar
how do u pull the trans from the motor dose it have to be i park or neutral
Old May 16, 2012 | 06:45 PM
  #17
crispin's Avatar
dude you are not using the service manual?
DL it for free right here on this site and print out the pages you need.
That is how I did my 5 speed swap
Trans, to remove first pull the access cover at the bottom, then you will see the tourque converter, undo the 4 bolts holding the converter to the flexplate, then unbolt all the bolts holding it to the engine, slide it away --- IT IS SUPER HEAVY!!
Old May 16, 2012 | 06:54 PM
  #18
eg6civic's Avatar
im new to this and still dont know to use this site
Old May 16, 2012 | 07:32 PM
  #19
crispin's Avatar
Old May 18, 2012 | 11:49 AM
  #20
eg6civic's Avatar
ok i need help again i cant take the flax plat off i try useing some of my sockets but its not griping on the bolts
