need help deciphering codes
Old Mar 15, 2014 | 02:05 PM
Banky's Avatar
Default need help deciphering codes
My engine check light is flashing the codes 7, 6-5 & 19-2 or192 can someone please tell me what these r if u have the info on it. Thanks.
Old Mar 15, 2014 | 02:15 PM
Put your car's information in your signature. Since I read your first thread, this is an 06 and OBD2.
I would drive to a parts store and have them read engine codes for you. Or use a scanner if you have one. The codes will start with the letter P and have four numbers, like P1234.
Post your codes on here.
Old Mar 15, 2014 | 02:34 PM
Banky's Avatar
Sorry I don't have a scan tool I just use a wire to jump the datd link
Old Mar 15, 2014 | 03:34 PM
I just looked in the shop manual, and there are numbers next to the codes. Code 7 is for the throttle position sensor, 65 is the secondary o2 sensor, and 192 is for the engine coolant temperature sensor.
Is the car drive-able? I would drive to a parts store like autozone to have them give you the obd2 codes, because they are more specific.
The codes can be caused by the sensor, the wiring, a bad connection, or possibly the PCM, So don't start replacing parts until you diagnose a problem.
Old Mar 17, 2014 | 12:58 PM
Banky's Avatar
Thanks a lot. I really appreciate your help. I changed the coolant sensor a few weeks ago. There was a sensor on the radiator that that wasn't pluged in and a plug wire was loose. Guess after the accident they changed the radiator but the sensor plug was different however I spliced the wire and connected the plug which was on the sensor. My cooling fans use to run constantly but since I did that they started only when the engine got hot. I'm gonna check the wires and make sure they r not touching since I didn't cut them. I picked them out the plug wire that was hanging and the plug on the radiator I just stripped it and slpiced it.
Old Mar 17, 2014 | 01:00 PM
Banky's Avatar
Whenever I switch the car on I can hear a rough sound coming from the TP sensor guess its going bad so I'm gonna check that too and see what the oxygen sensor is all about.
1993accord
Jul 20, 2010 11:58 AM
90accord90
Jan 19, 2010 04:49 PM
Mysticalbeauty3
Oct 6, 2008 04:17 PM
Mysticalbeauty3
saad180
Jan 3, 2007 10:45 PM
