need help trying to check engine codes
Old Jan 16, 2010 | 01:48 PM
90accord90's Avatar
Default need help trying to check engine codes
i have a 1990 honda accord i found the 2 prong connector its blue and not connected to anything.... its in the area of the passenger kick panel....
I did the paper clip thing to connect the two prongs
(does everything sound like im doing it right so far)
I turned the key to the 2nd positon then stared at the blinking lights...
Well theres two openings to the panel covering the computer
The one on the left is just blinking a lot
the one on the right is really hard to tell its kinda faded but theres a red dot there to
(what one do i look at for the long or short blinks)
(how long do i have to watch the lights)
Plz let me know thanks
Old Jan 18, 2010 | 09:34 AM
This belongs in General Tech, I'll move it there so you have better chance of someone answering it. I don't know 1990 Accords all that well...
Old Jan 18, 2010 | 11:33 PM
90accord90's Avatar
Okay thank you
Old Jan 19, 2010 | 04:22 PM
There are two computers with red lights. One is for the engine (ECU) and the other is for the transmission (TCU). The one on the left is the ECU and the right is the TCU.
If both are blinking, then you should read both of them and post them on here. Also, shorting that connector may have the check engine light blink the ECU code for you. And the S or D4 light may blink the TCU code. I am not certain when the accord started flashing the CEL for the code.
The code will repeat itself, so keep counting until you it starts repeating.
Old Jan 19, 2010 | 04:49 PM
And... if you have a manual tranny, there is NO TCU.
dacecil
Jun 21, 2012 06:27 PM
VI009DZ
Nov 6, 2011 09:48 PM
coup de grace
Jun 8, 2008 01:39 PM
DadofFour
Oct 10, 2007 06:34 AM
saad180
Jan 3, 2007 10:45 PM
