Need help! Finding a front wheel hub assembly for 97 accord ex 2.7 v6
Old Apr 16, 2025 | 05:40 PM
C.laswell's Avatar
Default Need help! Finding a front wheel hub assembly for 97 accord ex 2.7 v6
Need help finding a front wheel hub assembly for my 97 accord ex with the 2.7 v6. I took the knuckel up to a shop to get the bearing pressed out and while they were looking at the new parts their scrap guy came by and took my old assembly. Come to find out the part I received were for the 2.2 and now I'm stuck with the correct bearing but can't out it back together. Hoping someone can point me in the right direction. I knkw the parts for this car are scare seeing how honda only made that model for 2 years
Old Apr 16, 2025 | 08:24 PM
Is the bearing the correct bearing and you just need the hub?
Old Apr 16, 2025 | 09:01 PM
C.laswell's Avatar
it's the correct bearing i just need the hub. after more research i can use the same hub thats on the 97 acura cl.
Old Apr 17, 2025 | 12:18 PM
If you are replacing both front hubs, you could also go with the 98/99 V6 CL hub and rotor and essentially have the normal hub/rotor setup instead of the captive rotor setup.
Old May 5, 2025 | 11:40 AM
C.laswell's Avatar
Would have have to change the knuckel as well or could I still use the one that already on the accord. Cause find parts for either car has been a pain
Old May 5, 2025 | 02:29 PM
The knuckle is the identical between the V6 CL and the V6 Accord, so you don't have to swap them. I am pretty sure the 4-cyl CL has a different knuckle part number. Not sure where you are sourcing the parts, but I'll suggest to write down the OEM part numbers for your car on a site like hondapartsnow.com and also the OEM part numbers for the donor Acura CL on an OEM parts site for Acura to be 100% sure. You want to make sure the donor vehicle has the same knuckle and bearing part number. The hub and rotors will be different, because the accord has the hub over rotor design, and the Acura has the normal hub/rotor setup.
When I did this swap on my 4-cyl 95 accord, I found a great price for the 4-cyl CL knuckle and hub. Since the knuckle was identical, I swapped the entire part as it was easier than swapping over just the hub/bearing assembly.
Jasons2.7
Dec 12, 2021 11:48 AM
TexomaAccord
Apr 9, 2014 11:06 AM
miro066
Mar 29, 2014 08:13 AM
ryandamartini
Aug 15, 2011 09:18 PM
noahmoss
Jan 30, 2011 02:17 PM
