Need help with my 91 Accord lx
First step in fixing a no-start is determining whether fuel or ignition is causing no-start.
Suggest attempting to start w/ a long (5-10 sec) blast of throttle body cleaner or starter fluid in the air intake duct. Attempt to start.
If no-start continues, the ignition problem is highly likely; ignition switch assy, ignitor, coil are things to inspect.
If engine starts and runs briefly, then fuel delivery problem is causing no-start. This is usually Main Fuel Relay fault, or less likely sticking fuel pump.
99accordf23a5
May 6, 2014 12:51 AM
Levibyz
May 31, 2011 09:43 PM
