Need help with Transmission fluid change
Old Sep 25, 2009 | 05:51 PM
voteforpedro's Avatar
Default Need help with Transmission fluid change
I would like to change my Transmission fluid - for the first time and am following the Haines manual I picked up from Autozone. My car is a 2000 Accord EX.
My only problem is I'm not sure which bolt to take off to drain the trans fluid. The picture in my Haines manual is like a mirror image of what it should look like if I'm looking up from underneath my car.
** First, is this picture my auto transmission - secondly, do I have the proper bolt pointed out - as the drain plug ** . I'm about 70 % sure that I have the drain plug identified - I'd like to be 100 % sure.
Here's 2 photos I took ( of the same part ) - and I've marked the bolt I think is the one I need to remove to change my trans fluid. I'd like to get a confirmation before I unscrew the bolt - don't want to cause any damage.
TransmissionFluidChange1.jpg?t=1253918689
TransmisssionFluid2.jpg?t=1253918734
Also, there is some rust on the bolts - do I need to replace them - or is it just surface rust that I don't have any need to worry about - just unbolt - drain - and put the bolt back into the tranny - and refill with fluid.
Thanks
Old Sep 25, 2009 | 08:14 PM
Exclamation Hi Member
Im pretty sure but dont quote me ...that the bigger bolt is the one...loosen it up and stick your finger there and smell if its trans fluid...
Old Sep 25, 2009 | 10:39 PM
So the Fluid plug will be bigger than the rest of the Transmission bolts? If so, that'll help narrow it down clearly for me. I can bring a couple sockets under the car - to narrow it down.
I want to change my fluids either Monday - or sometime this weekend - so I'll see if others weigh in. If not, I'll follow what you suggest.
BTW - what's Transmission fluid smell like?
Thanks for the reply.
Old Sep 26, 2009 | 10:54 AM
F22ovaH22's Avatar
On my 96 the bolt is located behind the passanger side wheel on the side of the tranny. its not a regular bolt it has a square groove to fit a socket wrench head.
Old Sep 26, 2009 | 07:04 PM
Thanks,
That answered my question - I jacked up the car and checked out the bolt - and I've got it identified now. Mine has a square hole in it too - my socket wrench fits in there just fine.
It's been a while since my Trans fluid was changed. Would you recommend a new washer - or should I just keep using the one that's on there now.
I'm new to this DIY auto servicing - but it's kind been fun so far, Right now, just done the oil - and will be doing the trans fluid in the next day or two. Over the next few weeks - I'll be doing all the routine maintenances and replacing fluids whereever I can.
Old Sep 26, 2009 | 09:30 PM
F22ovaH22's Avatar
I hope you are using general honda ATF fluid, its the best way to go. Also i would not recommend using the same washer as it may cause leaks.
Old Sep 26, 2009 | 09:33 PM
I picked up some Transmission fluid from Autozone. They had some foreign car blend that's made for Hondas, Toyotas, etc.
Old Sep 27, 2009 | 07:48 PM
F22ovaH22's Avatar
I used the one from the dealership but im not sure about those. They used That stuff on my car and after like 10k miles it wouldn't shift right. Like it would shift hard.
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
logannz
Mar 30, 2013 05:20 AM
93Accord2.2
Jan 20, 2012 01:02 PM
62maxx
Nov 21, 2006 12:04 PM
