need help with VSS
Old Dec 17, 2011 | 11:40 AM
rberens60's Avatar
Default need help with VSS
please advise me! i went to change the VSS in my accord and there was NO plug for it. it is straight wired into the sensor! how can i get a replacement plug so i can fix my VSS.
Old Dec 17, 2011 | 01:24 PM
Huh, got pic's?
Old Dec 17, 2011 | 03:03 PM
Did somebody cut off the electrical connector and hard wire the VSS?
If that is the case, I would go to a junkyard and cut the harness that goes to the VSS. Then splice the harness into your car's harness.
Old Dec 17, 2011 | 06:12 PM
rberens60's Avatar
i figure it was cut off, and thanks for the advice i attempted to go to pull-a-parts but could not go in cause they wont let me take my 5yr old son in the yard, but as soon as i can get back up there that is exactly what im gonna do is cut another off and resplice it onto mine, i am sure that is what the problem is with the speedometer.
Old Dec 18, 2011 | 07:24 AM
Is the cruise control working.......usually if the VSS is bad it will set a code.
Speedo not working could be something else.....like a bad PCB
Old Jan 8, 2012 | 12:31 PM
rberens60's Avatar
i finally got the problem fixed! i tried to upload a pic of the old VSS but am having trouble transferring pic from phone. any way,what they did was take the wires and pushed them on to the sensor and then put some Hi-temp RTV on it to hold it in place and keep water out(that's what i figure anyway), long story short found a plug at pull-a-parts and spliced in on my car and put the new VSS on plugged it up and now i know how fast i am going! thanks for the advice check back later i will have a pic of the old VSS.
joe94wag
Dec 7, 2014 12:08 AM
chrisjames105
Aug 17, 2011 08:06 PM
loadder
Mar 3, 2011 08:52 PM
mjhenks
Feb 12, 2010 04:29 PM
comptoncarl
Feb 8, 2007 03:04 PM
