need a new catalytic converter. which to replace with
as title states, our accord needs a new cat. obviously an oem honda one is really expensive and want to go save a bit of money with going aftermarket.
here is the description to one I am thinking of getting from rockauto. Should work find without throwing a cel right?
BOSAL Part # 0993672 Direct Fit; Not Legal For Sale in the State of California Direct Fit
Sedan, Coupe; Federal Emissions; O2 Sensor in Center; Standard Load
ULEV engine never came with manual trans. Has the engine been swapped? If so, is it actually operating as a ULEV? What ECU is being used?
If it's really the ULEV engine, you'll have to be careful about getting the proper cat. I don't know if the price difference is LEV vs. ULEV or something else.
I say its a ULEV because the valve cover says ULEV-Vtec on it. dont know if that is a silly assumption to make or not.
We had the car since new so no engine swapping and I dont know how to check the ECU in the accord.
found this, so looks like they did put ULEV in MT accords in 01
http://www.hondareports.com/specific...w-side-airbags
we actually have two 01 accords now, one EX and one LX and both have the same valve cover saying ULEV.
You're right, I guess that's different from year to year. I remember looking up for someone else, but it might have been 1999 & I assumed it was the same for all 98-02.
I just looked up, & it seems to be different converter according to Honda's part number. DX, LX, EX all have the same converter but the EX-ULEV shows a different one. So when you find a converter, be sure the applications list makes a difference between the converter for a ULEV engine vs. a non-ULEV engine.
I don't actually know WHAT the difference is.
I ended up going with that bosal that I had mentioned. cost me $300 shipped off amazon. got it on the car, everything fit no problem and no CEL from it. car is running good and quiet. Still have a CEL from the egr but at least its not from the cat!
Taimoore Rajah
Jun 17, 2022 12:55 PM
mamtsberg
May 27, 2013 01:55 PM
odehboy
Sep 21, 2007 10:18 PM
thunder_x
Jul 13, 2007 01:50 PM
