need some help..
i have a 91 se im having problems it runs fine at first when i go about 3 blocks it runs like POO the engine light comes on and it runs fine any way to check codes without a scaner.uh i can turn it off a back on and it runs fine..... thanks for any help//// sorry i did not read the read first i didn't have it scaned yet? its a 91 se 2.2L auto.4d. power eveything/its my first honda never go back to the little dodge's. my little honda got a lot more balllllllllllllllllllllls?????
Thanks for the post.... You can either go to autozone and have them scan the code for free or look through this forum for OBD 1 Diagnostics and it will give you the procedures to read the codes yourself and then post them.... When you say it runs bad what does it do? sputter? jerk? die? underpowered? what?
on the passenger side there is a blue connector under the right side kick panel. jump the two terminals and turn the ignition on and count the flashes the check engine light makes on the dash. that will tell you the code. it sounds like you have an o2 sensor going out. autozone actually wont be able to check the code because your car is not obd-2
well autozone said they cant help me becuase they do 95 and newer.so someone told me to jump the wire and i got 4 slow flashes then 3 fast ones. 3 means map 4 means two different things ckp sensor are vaccum switch ps to the makers of honda auto form thanks for the place to get help wish there were more poeple like you......
4 slow & 3 fast is code 43. That's kind of a generic catch-all fuel-system code that could be from a bad O2 sensor, bad injector, or incorrect fuel pressure or a few other things.
