Need Wiring Diagram
Old Feb 4, 2012 | 08:48 AM
crispin's Avatar
Default Need Wiring Diagram
Hello
While pulling out my motor and trans I pulled too hard on this connector and pulled the wires out.
Can someone tell me where they go?
It is the connector right under the distributor.
There are 4 wires
Please and thank you
Old Feb 4, 2012 | 09:17 AM
Looks like the wires to the ICM/coil....external coil on this?
Old Feb 4, 2012 | 11:43 AM
crispin's Avatar
well those are the same colors except for the black wire however this looks like some kind of temp sensor.
Here I circled where the wires pulled out from.
again thanks for the help!!
Old Feb 4, 2012 | 12:55 PM
That is the ECT, only two wires to it? If they are the same on the 97 vs 95, majestic has the part number the same 37870-PK2-015 for a 95EX to a 97EX. Then there is a single black wire to the temp gauge sender.....just to the right in your pic.
I show the wires to the ECT as GRN/BLU and RED/WHT for a 95.
Old Feb 4, 2012 | 01:01 PM
crispin's Avatar
you are right, the black does go to the sensor next to it on the right.
I am going to pull the connector off and get a better look at it.
However those 3 wires go into the connector for sure.
The wires are
Green
Yellow
Green with yellow dashes
Old Feb 4, 2012 | 01:33 PM
Hey its cool....you are there I'm not....all I get to do it read thru the diagrams to see if I can help....I'll keep looking for you and see what I can find
Old Feb 4, 2012 | 04:13 PM
crispin's Avatar
OK - I looked more carefully.
You are right, those 4 wires are coming right out from the base of the distributor.
The other connector that I circled did in fact only have 2 wires going to it, I repined that connector with its 2 wires. I assumed that it did not matter which pin went in which hole as it is most likely just a temp sensor of some type.
Anyway as for the 4 wires coming out of the distributor I looked and looked and did not find a connector anywhere that was missing its wires.
The diagram you posted up is def the right one, those are the wires. The ICM is located in the Dist, right? I guess when I put the motor back in (Monday or Tuesday) I should find the connector they belong in. However, I will need to know what positions they have to go in unless the colors match on both sides of the connector (I hope they do)
So thank you Poorman for the help so far.
Old Feb 5, 2012 | 06:59 AM
On the ECT, I think it does matter....or at least I'd bet a cup of coffee on it. The ect is a "resister" of sorts. One wire is + the other is -.....again I'm not an electrical engineer, I'd have to call my Dad. These feed back to the ECU to tell it when the engine is warm/cold and it can adjust "things", if you will, the "choke" for a FI engine.
For the others, is there an 8 pin and 2 pin connector near by....is one or both of them missing a few wires? EDIT: or what plugs into the coil, if it is external....4 pin
Old Feb 5, 2012 | 07:46 AM
crispin's Avatar
While I do not think it matters I will check the positions I put the 2 wires in for the ECT and if I have it different than the diagram I will change it.
Thanks for pointing out that the 4 wires could have pulled out from a 8 pin connector.
I was looking for a 4 pin connector missing it's wires.
What you said was kinda obvious but it just didn't occur to me, so thank you very much for the help. I will check it out today and figure out where they went and hopefully you will be able to find the diagram that shows the positions they go in.
Thank you very much for your help!
toptech
Nov 29, 2009 06:43 PM
qbantaz
Dec 9, 2007 12:04 PM
jhowkins
Aug 23, 2007 05:42 PM
wasaland
May 14, 2007 05:03 PM
chico_dA_man
Mar 15, 2007 01:01 AM
