New Accord Owner
Old Jun 18, 2015 | 08:48 PM
TankDX's Avatar
Default New Accord Owner
Hey Honda Lovers!!
Just so this doesn't turn into a repeat thread, please direct me to the correct area on here if this topic has been discussed before, or if there is a spot on here with pictures, that would be even better. So here is what I have going on....
My younger brother got this 94 Accord DX from his wife's brother, and prior to that it was a one owner bought new by the wife's grandma. It was a daily driver, and after my brother got it, there was a noticeable ticking noise under the hood. After taking it to a local Honda guy, it was determined that there was a bent valve, and an oil leak. I will say that after taking a look at the motor(mind you I have not owned a Honda till this one), I am not a big fan of overhead cam motors. I don't have a ton of experience when it comes to messing with timing, so I guess here is my first question. Can the head with the cam assembly be removed all as 1 unit? Will the cam move freely after I undo the timing belt?
I am not looking to do a build, just get it back to running and driving. When I get the car picked up next week, I will try to post pics as I go along. Any advice, points in the right direction, is greatly appreciated. Thanks in advance..Oh...also, this might help..it's a 2.2 VTEC..5sp.
Old Jun 18, 2015 | 08:59 PM
How did they verify the valve is bent? Where is the oil leak?
The head and cam can be removed as one unit.
Old Jun 19, 2015 | 08:11 AM
TankDX's Avatar
the guy my brother took it to is a well known Honda mechanic in our area, I don't know exactly what he did or looked at. I haven't had the chance to locate the leak yet. I won't have the car in my possession till next week. I don't have a certain amount of time to get it running, but I don't want to throw a bunch of parts at it, with no end result.
I will try to get ahold of my brother to get some more info, he travels for work, so it's hard to get ahold of him...
Old Jun 23, 2015 | 09:15 PM
TankDX's Avatar
Apparently the valve seals are shot, lots of blue smoke coming out the tail pipe, and the spark plugs were fairly saturated with oil. So regardless, I have to remove the head anyway. Might as well learn as much as I can...
Old Jun 26, 2015 | 09:13 AM
TankDX's Avatar
The valve is bent...it's easily seen. I tried to post a picture from my iPhone but it keeps kicking me off safari...also have a broken rocker arm
Old Jun 26, 2015 | 09:32 AM
shipo's Avatar
Sounds like the timing belt broke which in turn caused the bent valve.
jjenkins427
Aug 20, 2011 02:28 PM
knann
May 14, 2010 01:06 AM
lairdylairdy
Feb 22, 2009 12:37 PM
DIGI ENT
May 2, 2008 12:54 AM
kumazam
Mar 6, 2008 04:05 PM
