New car
Old Feb 15, 2011 | 12:54 AM
Supernaut's Avatar
Default New car
So I just bought a 1991 accord coupe DX with an AT. The car seems to run fine but the tranny sometimes seems to want to hold the gear a tad longer than seems normal. It doesn't do the classic slip...just seems to be in "sport mode" even when not in sport mode. Am I crazy and this is normal for Honda? I am usually a Ford guy so I am not used to Honda's dynamics.
Old Feb 15, 2011 | 01:17 AM
I would change the fluid using Honda ATF.
You may also want to adjust the cable that goes between the throttle body and transmission. Copy and paste the link below to see what I am talking about. I would adjust the slack in the throttle cable too. You want to take up most of the slack.
media.honda.co.uk/car/owner/media/manuals/accordManual/400/9-90.pdf
Old Feb 15, 2011 | 02:11 AM
PAHondas got you covered there..do what he said for starters..
Old Feb 15, 2011 | 08:43 PM
Supernaut's Avatar
Sweet! Thanks guys!
Old Feb 15, 2011 | 08:49 PM
Supernaut's Avatar
I will change the tranny fluid with Honda fluid and the filter as well and check that cable and let you all know if that makes an improvement. Thanks again.
Old Feb 17, 2011 | 08:50 PM
Supernaut's Avatar
Ok....I readjusted the throttle cable which helped everything out a lot. The throttle response is night and day (as it should be) and tranny seems to shift a little better...not so hard. Still need to do a flush and swap out the filter though.
Thanks for the throttle adj suggestion!
Old Feb 17, 2011 | 09:15 PM
Glad the cable adjustment helped.
You can't change the transmission filter on an AT accord, unless someone installed an external one.
You shouldn't have the transmission power flushed. Drain (you only get ~ 3qts out of 9 total), refill, drive minimum of 15 minutes. Repeat two more times. This will exchange most of the fluid.
Old Feb 17, 2011 | 09:39 PM
Supernaut's Avatar
Good to know. Now I won't sound like a retard asking for a filter that doesn't exist LOL.
I checked the dipstick though and the fluid looked very fresh. Is honda atf the typical red color?
gd13
Jan 3, 2014 12:41 AM
wannakeepmy94Accord
Mar 14, 2012 02:05 PM
2010couper
Jul 8, 2010 05:11 PM
giffink
Aug 31, 2007 08:58 AM
giffink
Aug 30, 2007 10:16 PM
