New guy... Looking for advice on stock-car....
Old Oct 22, 2008 | 08:55 PM
Wheel_Man
Default New guy... Looking for advice on stock-car....
Hi there guys,
My Dad and I race stock cars and I'm looking to build an Accord for my first car in the Fun-Stock division. I was wondering if you guys could recomend which model I need to find. Rule restrictions are, 1993 or older, 2&4 doors, hatchbacks and wagons, 4 cylinders max, Must be naturally aspirated, must be automatic,No DOHC, no V-Tec, ZC(?) or multi-port. I was thinking of a 1993 Accord with the F22A7 as long as it doesn't break any of the rules... (http://www.peterboroughspeedway.com/...un%20Rules.pdf)
I'll admit, I know very little about Hondas and any information you guys could provide would be greatly appreciated.
Thanks,
Keith
Old Oct 22, 2008 | 09:01 PM
finch13's Avatar
Default RE: New guy... Looking for advice on stock-car....
No multi-port? So no fuel injected vehicles? Honda before 1990 were 2bbl carbeurated and after 1990 they wer PGM-FI Fuel Injected.
Old Oct 22, 2008 | 09:07 PM
Wheel_Man
I believe that is in refrence to 8 valve per cylinder engines. Fuel injection is allowed, and the accord is on the list of allowable cars, I'm just curious which engine to look for.
Old Oct 22, 2008 | 09:16 PM
finch13's Avatar
Any Accord engine will work except the V6 ones (C27, J30, J32, J35)
Old Oct 22, 2008 | 09:24 PM
Wheel_Man
I have no idea what ZC is in the context of a Honda engine, but I just want to clarify the the F22A7 is not V-Tec, ZC or multi-port...lol. Also, I've heard that with many Honda engines (such as the H22 and the B16), you can retard the timing by moving the timing belt back a tooth for more horsepower. Does this apply to the F22A7? Can you chip the computer? Are there any other "cheap/free" horsepower mods?How many horsepower could I be looking at in "stock" trim?
Old Oct 22, 2008 | 09:31 PM
finch13's Avatar
Yes the F22A7 fits your regulations. On my old F22B2, I could retard/advance timing 6º by twisting the distributor. I'm not sure how many degrees a single tooth is, but all the 4 cyl have timing belts.
Old Oct 22, 2008 | 09:38 PM
Wheel_Man
Any idea how many horse can be gained through retarding the timing? Is there a better section to put this thread in? I'm new (obviously) and I'm not sure where to put things yet...lol.
Old Oct 22, 2008 | 09:44 PM
finch13's Avatar
Um, general tech help would have been good, or engine/internal, but I honestly don't look at what section it's in, just whats near the top in "Today's Posts".
ECU tuning can be done to adjust the adjust timing electronically, adjustable cam gears can be used to adjust timing mechanical at the cam.
Old Oct 23, 2008 | 05:13 AM
Antarctica's Avatar
Just my opinion, I'd get a 93 EG Hatchback (Civic, of course). It's got 70 HP (D15B8 engine) but it could fly. The car itself weights 2094 lbs, and the car itself needs to weigh at least 2200 lbs. I'd say throw in exactly 106 lbs. of sandbags in the back of the hatch, lol. Good luck though.
Old Oct 23, 2008 | 03:00 PM
Wheel_Man
Way I see it, I'lltry to run at the minimum weight (2200 including driver + 150 poundsfor Hondas)regardless of what I'm running. I think the 55-80 extra horse will make a big difference,unless the Civic has significantly different suspension than the Accord. Or are you saying there aren't 866 pounds to remove from the car?In addition if I were to go with the Civic,is there anyreason not to go with the 102 HPD15B7 over the 70 HP D15B8 engine?
Frankenstein94
Oct 29, 2014 01:02 AM
gd13
Jan 3, 2014 12:41 AM
sidthekid
Apr 13, 2013 11:15 PM
giffink
Aug 31, 2007 08:58 AM
giffink
Aug 30, 2007 10:16 PM
