New member having transmission shifting issues
Old Mar 12, 2012 | 10:04 AM
samsteve4u@yahoo.com's Avatar
Default New member having transmission shifting issues
Have Honda Accord 2000 model, am currently having issues with transmission shifting, from 1 to 2, it use to hesitate while moving from this 1 to 2, especially when the landscape is not level, others shift very well. Also shifting backwards to 2 is not smooth.
Within 1000 miles i have changed my ATF oil twice to solve the probs.
Scanned the ECU twice, no error code from the transmission, the only error from the main system (engine) is the O2 sensor.
What is the cause and what do I do to solve the problem?
Last edited by samsteve4u@yahoo.com; Mar 14, 2012 at 12:58 AM. Reason: need to add more information& correct errors
Old Mar 12, 2012 | 10:14 AM
Scar_cle's Avatar
Whats the mileage on this trans?
The drain & fill is a good start...But depending on mileage, that may be the sign of a trans that about to fail?
Old Mar 12, 2012 | 11:08 AM
crispin's Avatar
The 98-02 are known to have very faulty transmissions.
Have you tried pulling the codes from the ECU?
Old Mar 14, 2012 | 12:22 AM
Scanned the car twice no error code from tranmission, the only error code is the O2 sensor from the main system. The milleage is 192,011.
Old Mar 14, 2012 | 01:02 AM
Hi New Member..I moved your post to this forum..it was not posted in the correct forum..
Thank You for joining the HAF.
rg2415
Apr 6, 2012 10:43 PM
Dannyboi40
Feb 2, 2011 03:47 PM
hansw3
Nov 20, 2008 08:25 PM
93AccordCoupeLX
Mar 26, 2008 03:58 PM
90 accord lx
Jun 11, 2007 06:51 PM
