no a/c at all!!
Old Jun 30, 2009 | 05:13 PM
Shooter's Avatar
Default no a/c at all!!
hey guys this is my first post, so let me know if I screw up. anyways I am having a problem with my 2001 accord dx, that I cannot figure out. as the title states the a/c isn't working at all. the a/c button lights up when you push it, but nothing happens, no fans, no clicking, no anything. Have checked pressure, it's fine. I have checked all the fuses, so they're good. Traced the circuit from the a/c button to the underhood fusebox, where the relays are. as far as I can tell, it's getting power to the box, but from there on I have nothing. Now I have been reading up on this, and have seen that it could be the a/c diode, a/c thermostat, or ecm, right? however i cannot be sure of the location of these parts other than the ecu because I can't seem to find a wiring diagram/service manual for this model of accord's, the 1998-2002, and I've searched all over the internet it seems. Can someone point me to one? there seems to be one for every year model accord but mine! any help is greatly appreciated, and if you need more info please let me know.
Old Jun 30, 2009 | 06:21 PM
Online manuals thread in DIY section has links to sites with 98-02 shop manual. Its an iso file, so you'll have to burn it to a CD.
The a/c button in the car grounds the circuit to turn it on. At the pressure switch, you can test for continuity to ground at the plug to figure out which direction you need to troubleshoot.
Old Jun 30, 2009 | 06:45 PM
Autozone.com has manuals online and you may be able to get a wiring diagram.
If the blower is not working w/ and w/o AC, the blower resistor may be completely open, or the blower switch may be damaged. This would disable AC also.
Old Jul 31, 2009 | 08:29 PM
Shooter's Avatar
hey i figured out my problem. it was a broken wire! specifically the pressure control switch ground. fixed that and rebuilt my compressor and I now have cold a/c!! thanks for the advice hope this can help somebody else.
Old Aug 3, 2009 | 07:43 AM
Thanks for telling us what the fix was.
Old Dec 20, 2009 | 02:46 PM
Lightbulb
Any time you post your own fix, that makes it even much better to know it's been handled..
Thank You!
ultrarevvin1
Jan 11, 2014 06:54 PM
phantomgrey92
Jun 16, 2013 07:14 PM
May 10, 2007 12:04 AM
YeuEmMaiMai
Oct 23, 2006 09:20 PM
