No heat at highway speeds
Old Jan 17, 2007 | 10:01 AM
sanchezcruz_20
Default No heat at highway speeds
Hello all! I'm having some trouble with my 1990 Accord EX heater. In the mornings I warm my car up and it works just fine at idle and the cabin gets nice and warm, but once I hit the road for work via highway the heater is unable to keep up and it eventually gets cool in the cabin again. At idle the temperature gauge is at normal operating range, but at highway speeds the temperature drops to the cool side. Obviously I would expect the engine to cool a little with all that cool air rushing into the engine compartment at 70mph butI don'tthink mycabin temperature should be dropping this much, I'm pretty much needing to wear gloves inside the car.Any ideas?????? The fan blows fine just luke-warm airon the highway. Once I get off the highwaythecabin will eventually warm back up.Could it be a heatercore or thermostat issue? Thanks.
Old Jan 17, 2007 | 10:43 AM
Default RE: No heat at highway speeds
Sounds like a thermostat problem (doesn't close all the way). If it were just the heater core, the temperature gauge would act normal.
Old Jan 17, 2007 | 04:36 PM
sir_nasty's Avatar
Thermostat: It doesn't sound like it's closing and allowing the coolant to gain temp again so you've got a constant flow and it just slowly gets cold.... Replace it with a honda OEM one and you should be fine
Old Jan 18, 2007 | 09:40 AM
sanchezcruz_20
Thanks for the info guys. This a great forum... I'll change out the thermostat (with a Honda one of course) and hopefully that'll solve my problem.
Old Jan 18, 2007 | 01:12 PM
ArcticHonda's Avatar
Also replace the new gasket that comes with the honda stat
Old Jan 30, 2007 | 02:37 PM
sanchezcruz_20
Thermostat was changed out and everything works perfectly.... cabin is nice and toasty!
Old Jan 30, 2007 | 02:43 PM
sir_nasty's Avatar
Very nice! heat is good! luckily it wasn't a big problem!
wunderbra
Mar 15, 2011 11:13 AM
SI_dude
Nov 18, 2010 08:39 PM
wackoR
May 4, 2008 10:23 PM
thunder_x
Nov 2, 2007 06:11 PM
00AccordLX5spd
Mar 22, 2007 06:36 PM
