No power to driver side window
Old Aug 23, 2024 | 05:14 PM
Crr's Avatar
Crr
Exclamation No power to driver side window
Power window on the driver side stopped working on my ‘04 accord a week ago. Unfortunately it is stuck in the down position I can’t spend much on it right now so I wanted to raise it to the closed position. When I took the door panel off and lifted from the bottom it didn’t budge.
is there any way for me to lift the window into a closed position by hand?
Old Aug 27, 2024 | 01:28 PM
Moved your post to gen tech help where you'll get a resonse.
You can try supplying power and ground to the window motor connector to get the window to move up or down. The power and ground wires should be the thicker wires to the connector if there are more than 2 wires to the connector. If the motor is good, power and ground will roll the window up, or roll down if you switch power and ground. Hopefully the motor is still working.
Old Aug 30, 2024 | 12:52 PM
nomad2020's Avatar
when you say no power did you actually chk with voltmeter or test light that there's no power at motor plug or are you assuming that cause window won't move
if you have not actually checked for power could be a bad motor , tap on the motor while you hold the up switch see if it moves
if it does not, do as PA suggested
radar78
Jul 15, 2012 07:56 PM
Bendezium
Jun 17, 2009 06:16 PM
scagle777
Oct 6, 2008 04:22 PM
jromero92
Dec 10, 2007 06:26 AM
zipharman
Aug 8, 2005 03:33 PM
