No Spark in 94' lx
Old Dec 5, 2010 | 01:36 PM
EducatedFool's Avatar
Default No Spark in 94' lx
The car will turn over all day long, sounds fine, just no ignition. Clearly no spark. Car has close to 200,000 miles on it, so almost all parts probably could use some work. Already replaced distributor cap, but still nothing. How would I tell If its something with the electric parts inside of the timer? Or whatever that thing is that sits right beneath the distributor cap.I'm almost 200% sure the problem is located in that area of the car(right around dist. cap)
Solutions or any other suggestions would be greatly appreciated. Sorry its so broad, not the best mechanic...
Old Dec 5, 2010 | 02:07 PM
First, suggest downloading the 94-97 Accord Manual from this site. This has tests for the ignition coil and ignitor. You will need a Volt-Ohm Meter (VOM) to test the coil primary and secondary resistance.
I believe the LX has the non-VTEC, B2 engine. Primary resistance is 0.4-0.6 ohms and secondary is 22000-34000 ohms. If resistances are out of spec, suggest replacing coil.
If resistances are w/i spec, ignitor is more likely the problem.
Old Dec 6, 2010 | 12:54 AM
deserthonda's Avatar
http://techauto.awardspace.com/ignition.html
this will help diagnose.........also chk the t-belt make sure that it is ok,,
sirtwist2
Sep 24, 2012 01:36 AM
SeanAccord
May 18, 2010 08:24 PM
superpimp12
Dec 29, 2005 10:24 PM
Mr.Luder
Dec 29, 2005 10:22 PM
hotrod20
Dec 4, 2005 11:04 PM
