No spark from distributor
Old Mar 7, 2017 | 11:35 AM
sean-boy73's Avatar
Default No spark from distributor
i have 2002 uk edition 1.8 vtec sport accord, problem started when car kept cutting out from time to time, sometimes at idle other times at speed whilst driving. after repeated attempts of car starting then cutting out after few seconds car would run fine again until it chose at random to cut out once more. I was informed that apparently accords of that year suffered very common problem with regards the internals of the distributor and should change it and this would solve problem i was having with car, changed distributor and now car is failing to provide spark from distributor at all, have tried changing distributor back to the one i took out but still no spark, is there any relays or fuses or anything at all that can be checked to ascertain why there is no spark??? please help someone, am at my wits end wityh problem now, many thanks.......
Old Mar 7, 2017 | 01:46 PM
How are you testing for spark?
Old Mar 8, 2017 | 07:32 AM
sean-boy73's Avatar
by removing spark plug from cylinder head and whilst it still connected to ht lead turning engine over couple of times to see if spark going from distributor to spark plug, which it is'nt. why?? is there another way at all that am not aware of???
sirtwist2
Sep 24, 2012 01:36 AM
SeanAccord
May 18, 2010 08:24 PM
gearshift
Apr 17, 2010 07:30 PM
helixblue
Oct 22, 2007 11:02 PM
LinX
Nov 1, 2005 12:38 AM
