No tail lights or dash lights. Help!
Old Feb 27, 2008 | 05:18 PM
eccsc01
Default No tail lights or dash lights. Help!
I have a 98 accord sedan. After installing an aftermarket stereo I have no dash lights or tail lights. The headlights and brake lights work though. Is there a fuse for the two of them together? I dont have the factory cover for the underhood fuse box. Any help would be appreciated.
Old Feb 28, 2008 | 07:07 AM
Mille 16i's Avatar
Default RE: No tail lights or dash lights. Help!
Answer is yes there should be a fuse for park/tail lights normally it is under the dash in that fuse panel normally towards the drivers side lower dash or on some cars the driver side kick panel. but the fuse is not your problem, either your radio is hooked wrong or you acidently shorted the curcuit during installation. All cars from the factory have a light wire going to factory sterios to dim the lights when you turn on your headlights so either you hooked it up wrong to your aftermarket sterio or if you cut the harness ( I hope you did not) it might be grounding out some how so what you need to do is figure out why you blew your fuse then replace the fuse.
EricGuevara83
Apr 28, 2014 02:15 PM
myfirstisanaccord
Apr 24, 2011 08:25 PM
Vettress
Jul 7, 2010 11:10 AM
dontevenfucwitme
Oct 31, 2007 06:07 AM
WhyNotFab
Sep 28, 2006 06:10 PM
